Can i create a jira issue from within Confluence
Frode Haugland September 28, 2016
I'm looking for functionality similar to the current JIRA macro in Confluence but with a configuration that determines - project | issue type | custom fields - all predefined.
This encapsulated in a create JIRA issue button that that gives me a screen with the predefined values and possibility to fill in say description field.
A resusable create new JIRA issue if you will.
Vladimir Horev _RaleyApps_
Bob Swift
September 28, 2016
If you want customized control, you can put a Run macro to restrict what can be done and then put a CLI Macro in the body to create the issue with the parameters input through the run macro.
Bart Meerveld
September 28, 2016
Susan Kraft-Yorke October 1, 2019
Bart's content is no longer there - it's been removed
Help us plant more trees
