Canot enable Collaborative Editing, synchrony won'T start
Carsten Grzemba September 3, 2020
I upgraded confluence from 6.15.4 to 7.4.3. After that I can't start or enable Collaborative Editing
In the attlassian-confluence.log:
2020-09-03 14:59:46,603 INFO [Long running task: EnableTask] [plugins.synchrony.tasks.AbstractConfigLongRunningTask] execute Removed 0 stale shared drafts.
2020-09-03 14:59:46,905 INFO [synchrony-interop-executor:thread-1] [plugins.synchrony.bootstrap.DefaultSynchronyProcessManager] isSynchronyProxyEnabled proxy port present: true
2020-09-03 14:59:46,936 ERROR [Long running task: EnableTask] [confluence.util.longrunning.ConfluenceAbstractLongRunningTask] run Long running task "EnableTask" failed to run.
-- url: /confluence/rest/synchrony-interop/enable | referer: https://jira.contac.lan/confluence/admin/confluence-collaborative-editor-plugin/configure.action | traceId: 4cee475a43588eea | userName: admin
java.lang.NoClassDefFoundError: Could not initialize class oshi.jna.platform.linux.Libc
at oshi.software.os.unix.solaris.SolarisOperatingSystem.getProcessId(SolarisOperatingSystem.java:186)
at com.atlassian.confluence.plugins.synchrony.bootstrap.DefaultSynchronyProcessManager.getConfluenceProcessId(DefaultSynchronyProcessManager.java:702)
at com.atlassian.confluence.plugins.synchrony.bootstrap.DefaultSynchronyProcessManager.setupEnvironment(DefaultSynchronyProcessManager.java:391)
at com.atlassian.confluence.plugins.synchrony.bootstrap.DefaultSynchronyProcessManager.trySetup(DefaultSynchronyProcessManager.java:709)
at com.atlassian.confluence.plugins.synchrony.bootstrap.DefaultSynchronyProcessManager.lambda$startProcess$1(DefaultSynchronyProcessManager.java:603)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at java.lang.Thread.run(Thread.java:748)
Java version:
java version "1.8.0_221"
Java(TM) SE Runtime Environment (build 1.8.0_221-b11)
Java HotSpot(TM) 64-Bit Server VM (build 25.221-b11, mixed mode)
OS version:
SunOS jira 5.11 11.4.14.5.0 i86pc i386 i86pc
Diego
September 15, 2020
Hello @Carsten Grzemba !
Looking at the error you posted here:
I believe that you are affected by the situation described here:
You can check the the workaround at the end of the Knowledge Base page. I do recommend that you read the entire page for a better understanding of the issue.
Let us hear from you!
SERVER
VERSION
7.4.3
