Checklist-wikiinput: No wiki rendering
Laurent Corbière
Using the Comalatech Checklist Plugin, I can't get a wiki format in a checklist-wikiinput when I refresh the page.
Here is the code:
{checklist:name=Reports|parent=Optimization Reports}
{checklist-input:In Charge|cols=20}
{checklist-select:Status}
Reported
Assigned
Solved
{checklist-select}
{checklist-input:Date Solved|cols=10}
{checklist-wikiinput:Solution|rows=10|cols=80|width=50%}
{checklist}
* edit the checklist-wikiinput
* write some wiki code (bullets, line break,..)
* the formating is correct
* refresh the page: the formating is lost
Is somebody has a solution please?
Thx
Ulrich Kuhnhardt
January 31, 2013
Hi Laurent,
unfortunately only a subset of text formatting wiki markup is supported such as {*+_-}. Bullets, enumerations and everything involving line breaks are not supported in the wikimarkup input column.
However Ad hoc Canvas renders all wiki markup in a wiki input column. Canvas is compatible with the Checklist plugin and can be installed alongside. Check out Canvas and let me know what you think.
Cheers Ulrich
Laurent Corbière
Hi Ulrich,
Thank you for your researchs.
Unfortunatly, we already have more than 40 plugins and it's a too much for our instance (upgrade problems, stability,...).
We'll keep using checklist-wikiinput without the formating: now, we know that it's not a bug :).
Have a nice day,
Laurent
Ulrich Kuhnhardt
January 31, 2013
Hi Laurent,
I'm looking into it.
Cheers Ulrich
Ulrich Kuhnhardt
January 31, 2013
Hi Laurent,
Cheers Ulrich
Register today
