Chrome 27. Confluence 5.1.3 Add Comments Editor does not load
Ivaylo Stanev
Hey,
We just upgraded to Confluence 5.1.3 Download.
All went smoothly except one issue. Add Comments Editor in Confluence did not work for me for all browsers I use: IE9, FF21, Chrome 27 on Win7. I reinstalled Java (now I have Java SE 7 Update 21) and restarted my PC. Now it works on all browsers except Chrome. My Chrome version is 27.0.1453.94 m. The RTE starts to load but never finishes. It is weird but for another team member, it works ok with the same browser version and OS.
I restarted the browser few times with no luck. Tried incognito mode, deleted the cache - no luck again.
Any suggestions?
Ivaylo Stanev
Simple Confluence restart seems to have helped.
Amalia
May 30, 2013
Hey Ivaylo!
Have you tried the following:
If none of the above helps, you may want to create a support ticket at support.atlassian.com
