Code Block Macro on Insert Menu?
The Diamond Z October 19, 2011
Our Confluence Wiki (4.0) has a lot of source code examples,
Is there:
  • A shortcut to insert a Code Block Macro (in the absence of markup)?
  • A way to get the Code Block Macro on the Insert menu when editing?
So at the moment I have to choose Insert | Other Macros | Formatting | Code Block
I'm hoping for something faster/easier
6 votes
David at David Simpson Apps
Doesn't the auto complete help you? I just type {code then hit enter. It seems to work better than using my mouse to achieve the same task.
Ah, I see the problem.
As a long time confluence user I'm used to typing the {code} macro with brackets.
If I type slowly enough, the auto complete catches up and inserts the new graphical block thing.
Not a fan.
Is there any way to set the defaults for a code block (i.e. we're always using the same language, same theme).
I've not noticed a lag problem with the auto complete, but have heard from others on Atlassian Answers that it can be slow. I must admit that I'd like it to just insert a code block when I type {code} or {code:lang=html}, but that's not the current behaviour. I'm sure they'll catch up and improve the editor a lot in subsequent releases :P
Joe Clark
October 20, 2011
You can configure the default language and theme in the plugin's administration page: http://confluence/admin/plugins/newcode/configure.action
Deleted user August 25, 2016
Although this is an old thread, I still did not find any solution like what David supposed... is there something?
Background: I type quickly, and inbetween I often need to insert code snippets of several code types. It is essential to have the possibility to set the code type by typing, not via mouse - with the mouse it needs actually too much time.
That is extremely annoying, and hence I hope, that maybe I just overlooked the needed feature?
Okay, got it myself, was just too much confused by the auto complete popup - typing "{code:language=bash}" did it f.e., and "{code:lang=bash}" seemingly, too (but in the latter case it is not preset in the edit formular). Before I had always typed "{code:language=bash<Enter>". That was the error. Closing the input with '}' opens the code box like expected.
It's a bit verbose, but it works for me.
Mahendar Muthu
April 30, 2019
This {code is not working in the latest version of JIRA
Adam Buga
August 7, 2019
I just noticed this...
I was uploading Markdown converted to HTML content via the Confluence REST API (during a Github Wiki Migration).
When using this method, I could have "Code Blocks".
On pages where I'm creating Pages form the Confluence UI, I have no such option.
I just get the generic non-themed text.
VVVV Created w/ Confluence UI
VVVV Uploaded via REST API...
Screen Shot 2019-08-07 at 3.57.48 PM.png Screen Shot 2019-08-07 at 3.58.54 PM.png Screen Shot 2019-08-07 at 3.57.25 PM.png
These seems completely wrong.
Dima Kovalyov
August 14, 2019 edited
It works with / instead according to:
https://community.atlassian.com/t5/Confluence-discussions/Try-out-the-new-editing-experience/td-p/1000813
A single autocomplete shortcut: Type / to open a menu and add macros, tables, emojis, mentions and more to your page as you go.
Like • William Walsh likes this
Help us plant more trees
