On a Confluence page we have an XML code snippet that includes a CDATA section, contained within a code block macro. This worked fine in Confluence 5.3.4 and 5.8.10.
<?xml version="1.0" encoding="UTF-8"?> <beans xsi:schemaLocation="http://www.springframework.org/schema/beans http://www.springframework.org/schema/beans/spring-beans-4.0.xsd" xmlns="http://www.springframework.org/schema/beans" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"> <bean id="a39-cronTrigForEventType44" class="com.emeter.hydrofw.scheduler.quartz.CronTrigger"> <property name="scheduler" ref="quartzScheduler"/> <property name="name" value="EVENTS_ANALYZER_Type44"/> <property name="group" value="EVENTS_ANALYZER_Type44"/> <property name="eventHandler" ref="a39-eventType44"/> <property name="cronExpression" value="1 * * * * ?" /> </bean> <bean id="a39-eventType44" class="com.emeter.eventsanalyzer.handler.EventsAnalyzerHandler"> <property name="eventTypeId" value= "44"/> <property name="eventsSQL"> <value> <![CDATA[ SELECT DEVICE_EVENT.SVC_PT_ID SVC_PT_ID, DEVICE_EVENT.EVENT_START_TIME, DEVICE_EVENT.EVENT_TIME, DEVICE_EVENT.INCOMING_DEVICE_ID INCOMING_DEVICE_ID, DEVICE_EVENT.INCOMING_DEVICE_TYPE INCOMING_DEVICE_TYPE, DEVICE_EVENT.DEVICE_ID DEVICE_ID, DEVICE_EVENT.DEVICE_EVENT_TYPE_ID DEVICE_EVENT_TYPE_ID, DEVICE_EVENT.ORG_ID ORG_ID, DEVICE_EVENT_TYPE.EVENT_NAME FROM DEVICE_EVENT, DEVICE_EVENT_TYPE WHERE DEVICE_EVENT_TYPE.DEVICE_EVENT_TYPE_ID=DEVICE_EVENT.DEVICE_EVENT_TYPE_ID AND DEVICE_EVENT_TYPE.DEVICE_EVENT_TYPE_ID= ? AND (DEVICE_EVENT.EVENT_TIME > ? OR ? IS NULL ) AND DEVICE_EVENT.EVENT_TIME <= ? GROUP BY DEVICE_EVENT.SVC_PT_ID, DEVICE_EVENT.EVENT_START_TIME, DEVICE_EVENT.EVENT_TIME, DEVICE_EVENT.INCOMING_DEVICE_ID, DEVICE_EVENT.INCOMING_DEVICE_TYPE, DEVICE_EVENT.DEVICE_ID, DEVICE_EVENT.DEVICE_EVENT_TYPE_ID, DEVICE_EVENT.ORG_ID, DEVICE_EVENT_TYPE.EVENT_NAME HAVING COUNT(*) >= ? ]]> </value> </property> <property name="scanType" value= "Offset From Now"/> <property name="eventDuration" value= "36280"/> <property name="eventThreshold" value= "1"/> <property name="actions"> <list> <bean class="com.emeter.eventsanalyzer.action.InsertSRActivityAction"> <property name="srList" ref="a39-srListForEventType44"/> </bean> <bean class="com.emeter.eventsanalyzer.action.InsertSRActivityReuseOpenSRAction"> <property name="srList" ref="a39-srListForEventType44"/> </bean> </list> </property> </bean> <bean id="a39-srListForEventType44" class="org.springframework.beans.factory.config.ListFactoryBean"> <property name="sourceList"> <list> <bean class="com.emeter.eventsanalyzer.data.ServiceRequest"> <property name="type" value="Internal" /> <property name="subType" value="Meter Reading" /> <property name="activities"> <list> <bean class="com.emeter.eventsanalyzer.data.Activity"> <property name="type" value="Meter Service" /> <property name="subType" value="Load - Disconnect" /> </bean> </list> </property> </bean> </list> </property> </bean> </beans>
However, in 5.8.16 if I edit the page and attempt to save or close, the browser becomes unresponsive. If I attempt to insert the code snippet into a new page, the page will save but the snippet will be truncated just before the end of the CDATA section. In 5.8.16 it seems that the code block is trying to interpret the CDATA section.
Here's the error in the log file:
Caused by: com.atlassian.confluence.content.render.xhtml.XhtmlParsingException: The XML content could not be parsed. There is a problem at line 58, column 11. Parser message: Unexpected close tag &lt;/bean&gt;; expected &lt;/property&gt;. at [row,col {unknown-source}]: [58,11] at com.atlassian.confluence.content.render.xhtml.StaxUtils.convertToXhtmlException(StaxUtils.java:468) at com.atlassian.confluence.content.render.xhtml.storage.StorageXhtmlTransformer.transform(StorageXhtmlTransformer.java:50) at com.atlassian.confluence.diff.DaisyHtmlDiffer.transformToHtml(DaisyHtmlDiffer.java:187) ... 294 more Caused by: com.ctc.wstx.exc.WstxParsingException: Unexpected close tag </bean>; expected </property>. at [row,col {unknown-source}]: [58,11] at com.ctc.wstx.sr.StreamScanner.constructWfcException(StreamScanner.java:630) at com.ctc.wstx.sr.StreamScanner.throwParseError(StreamScanner.java:461) at com.ctc.wstx.sr.BasicStreamReader.reportWrongEndElem(BasicStreamReader.java:3258) at com.ctc.wstx.sr.BasicStreamReader.readEndElem(BasicStreamReader.java:3200) at com.ctc.wstx.sr.BasicStreamReader.nextFromTree(BasicStreamReader.java:2832) at com.ctc.wstx.sr.BasicStreamReader.next(BasicStreamReader.java:1019) at com.ctc.wstx.evt.WstxEventReader.peek(WstxEventReader.java:306) at com.ctc.wstx.evt.FilteredEventReader.peek(FilteredEventReader.java:120) at com.ctc.wstx.evt.FilteredEventReader.hasNext(FilteredEventReader.java:70) at com.atlassian.confluence.content.render.xhtml.XmlFragmentEventReader.hasNext(XmlFragmentEventReader.java:51) at com.atlassian.confluence.content.render.xhtml.XmlFragmentBodyEventReader.hasNext(XmlFragmentBodyEventReader.java:41) at com.atlassian.confluence.content.render.xhtml.ForwardingXmlEventReader.hasNext(ForwardingXmlEventReader.java:28) at com.atlassian.confluence.content.render.xhtml.XmlFragmentEventReader.hasNext(XmlFragmentEventReader.java:51) at com.atlassian.confluence.content.render.xhtml.XmlFragmentEventReader.close(XmlFragmentEventReader.java:80) at com.atlassian.confluence.content.render.xhtml.ForwardingXmlEventReader.close(ForwardingXmlEventReader.java:58) at com.atlassian.confluence.content.render.xhtml.transformers.DefaultFragmentTransformer.transformFragment(DefaultFragmentTransformer.java:185) at com.atlassian.confluence.content.render.xhtml.transformers.DefaultFragmentTransformer.transform(DefaultFragmentTransformer.java:135) at com.atlassian.confluence.content.render.xhtml.storage.StorageXhtmlTransformer.transform(StorageXhtmlTransformer.java:45) ... 295 more
I upgraded both of my production instances to 5.8.16 last weekend before I discovered this issue. I can rewrite this code snippet to resolve the immediate problem. I'd prefer CDATA to be handled correctly within code blocks or at least fail gracefully because I never know when someone will add another code snippet like this one.
Or did I miss something? Is there a flaw in my assessment?
Teresa
Most likely related to this bug: https://jira.atlassian.com/browse/CONF-39968
Learn more
