Comala Management - Label for Submit button
Roberta Bortolotti
When a Submit transition is set in the workflow, is there a way to edit the label of that button that is displayed to the end user?
Vronik
January 17, 2025
Hi
Look at this article, maybe can help you
https://docs.comalatech.com/space/CDML/6833112548/set-label+macro
Regards
Roberta Bortolotti
Thank you, Vronik
I can't access this page. Is there another link that I can use?
Thank you,
Roberta
Roberta Bortolotti
Hi Vronik,
Just found the page via Google. I would like to edit the text of the button and not of the page per se. For example, instead of saying "Submit", I would like to show a different text.
Roberta
