Sign up Log in
ConfiForms: How to add values to a Jira JQL Field in ConfiForms
Florian Seibold
Hi, could someone help me with the Jira JQL field type in ConfiForms? I´m currently trying to automatically add values to an Jira JQL Field in confiforms, but none of the input i gave this field was accepted.
IRA JQL5.1+
Expects you to put a valid JQL, which will be executed for you and a number of matching issues will be shown (together with the link to JIRA search)
Ive already tried to add there a value like with a IFTTT Macro like JiraJQL="project=sup"
and a lot of other things but it was not saved / accepted.
Any hints are welcome.
Thanks a lot
Florian
Alex Medved _ConfiForms_
March 27, 2023
Hi @Florian Seibold
Have a look at this demo
http://recordit.co/4zBsRNLmrg
Alex
Florian Seibold
No thats not my case; I do not want to have field to type in anything i want to use some existing data and "build" the searchtag or whatever i need for this field by a ifttt. So my question is: What does the Field need as an Inpuit that i can copy with IFTTT?
March 27, 2023
Not sure why would you do that.. but here is another demo http://recordit.co/85lULgHXJz
Florian Seibold
Thanks a lot again.
Why I want to do that? - Because I have a big customer List where I want to do that for each of them.
My Problem was not the value it was the the filter of the ifttt ... myvalue is a checkbox. And I did a Filter that was like myvalue:true but it seems on an boolean there the filter doesn´t work like that. The value itself is enough.
Greetings & Thanks a lot
Florian Seibold
One more thing: What do i have to use when i want inside the value some other value? Simply use [entry.whatever] or asRef([entry.whatever]) or how?
March 27, 2023
Well, it depends :-)
What you want to "actually store"
If you are setting it through the IFTTT then asRef is needed, as otherwise it will evaluate agains the "current record"
Like Florian Seibold likes this
