Confiform and Velocity Question
Stuart Wosika
January 5, 2024
Hi guys,
I want to check a value is >= (greater than or equals to).  Below is an example.
I get errors If I do this.  The only operator I seem to be able to get to qork is == ( is equals to).
I read the Velocity documentation that says I can do this.
Can someone help please?
BR.
Stuart.
#set ($vasSize = "[entry.asSize]")
	#if ( $vasSize >= 0 )
   "update":
		"issuelinks": [
			"add":
				"type":
					"name":"Relates",
					"inward":"relates to",
					"outward":"relates to"
				"outwardIssue":
                          "key":"[entry.idea1]"
	#end
Alex Medved _ConfiForms_
January 7, 2024
Hi
Well, if you set the variable as text...
It is a bit too much to expect it act as a numeric in >= conditions
Alex
Stuart Wosika
January 8, 2024
Hi Alex,
sorry are you saying that if the variable is text rather than numeric then >= or <= works?
BR.
Stuart.
January 9, 2024
Please refer to Velocity templating documentation for more details
This defines a text variable
But this defines a numeric variable
#set ($vasSize = [entry.asSize])
Alex
Stuart Wosika
January 9, 2024
Hi Alex, thankyou for your patience and your support.  Silly mistake.  Now everything is working correctly. Regards. Stuart.
