Confiforms Filter Control macro
Archana
@Alex Medved _ConfiForms_
I have a confiform created on a different page and I am calling the confiform Filter control macro on another page.
When I select a field value and hit Filter it is displaying the desired table. However, I also want to display a dynamic text along with the filter Results. How can this be achieved? Any ideas are greatly appreciated. Thank you!
Sample View
<< Dynamic Test Should be displayed here after clicking Filter. This is not part of the table values>>
What text do you want to display and where? In a separate column in a table?
Archana
The text should not be part of the table. It should come below it. Here is a sample screenshot
Is this a dynamic or a static text?
Archana
March 26, 2024 edited
@Alex Medved _ConfiForms_ It is static text but should be displayed only on click of Filter
Why dont you want to show it always then!?
Anyway, what you want is also possible but with some more complexity - nested views.
Setting the filter to filter on the ListView and then having the TableView dynam,iclaly filtered inside
Something we show here https://wiki.vertuna.com/display/TEST/Dynamic+Filters+with+ListView+and+TableView
Inside the ListView you also put your static text (in addition to the TableView)
Like • Archana likes this
Archana
Thanks a lot. It worked.
Like • Alex Medved _ConfiForms_ likes this
