I have a table populated with a Confiform which has Domains and Programs (one to many).
On a new form, I want to select a Domain from a dropdown populated from this table.
Based on the Domain value selected, I want a second dropdown to contain the respective Programs for said domain.
The values should update dynamically, based on the Domain selection.
I can get this to work, however, the values in each dropdown are not distinct. The values get repeated, having the same number of rows in the table. (The same Domain/Program value will show 10 times, if there are 10 rows for that Domain/Program).
Here is my source code:
<ac:structured-macro ac:name="confiform">
<ac:parameter ac:name="formName">usingchoices</ac:parameter>
<ac:rich-text-body>
<p>
<ac:structured-macro ac:name="confiform-entry-register">
<ac:parameter ac:name="embedded">true</ac:parameter>
<ac:parameter ac:name="atlassian-macro-output-type">INLINE</ac:parameter>
<ac:rich-text-body>
<p> </p>
</ac:rich-text-body>
</ac:structured-macro> </p>
<p>
<ac:structured-macro ac:name="confiform-field-definition">
<ac:parameter ac:name="fieldName">mychoice1</ac:parameter>
<ac:parameter ac:name="fieldLabel">My choice 1</ac:parameter>
<ac:parameter ac:name="values">[277274429|esf|domain.name|true||]</ac:parameter>
<ac:parameter ac:name="type">smartselect2</ac:parameter>
</p>
<p>
<ac:parameter ac:name="fieldName">mychoice2</ac:parameter>
<ac:parameter ac:name="fieldLabel">My choice 2</ac:parameter>
<ac:parameter ac:name="values">[277274429|esf|program.name|true||]</ac:parameter>
</p>
<p>
<ac:structured-macro ac:name="confiform-field-definition-rules">
<ac:parameter ac:name="values">domain:[entry.mychoice1.domain]</ac:parameter>
<ac:parameter ac:name="action">Apply Filter on a field</ac:parameter>
<ac:parameter ac:name="actionFieldName">mychoice1</ac:parameter>
</p>
This is duplicate of https://community.atlassian.com/t5/Marketplace-Apps-questions/How-do-you-make-dynamic-dorpdowns-from-another-form-where-the/qaq-p/805571#U832994
Please see the advise on the mentioned question
