Confiforms: velocity multi-select field
Bartosz Drożdżal
Hi @Alex Medved _ConfiForms_
How can i use velocity with multiselect field?
For example i have 4 fields:
1. Checkbox Grup field:
a) ID - 1, Label - Option1
b) ID - 2, Label - Option2
c) ID - 3, Label - Option3
2. Dropdown Field
3. Text Field
4. Text Field 2
I want use if statement:
If i check in checkbox field only option 1 my description in jira be like:
"description" : "[entry.dropdown.label.escapeJSON]"
If i check in checkbox field only option 1 and option 2 my description in jira be like:
"description" : "[entry.dropdown.label.escapeJSON] and [entry.textfield1.label.escapeJSON]"
I have problem to create if statment for this expample.
Could you help?
February 14, 2024
