Confiforms: voting control not working, not counting votes.
karina ospina May 18, 2022
Hi
I need to get user feedback (confiform registration), show the list of topics registered (confiforms tableview) and allow users to vote for the topics we should discuss in a retrospective (confiform field type voting control).  I followed this tut: Quickly capturing employee votes on things that matter - Vertuna WIKI - ConfiForms)
After clicking vote on an item, the voting count doesn't increase it remains 0 no matter what, the vote button doesn't change.
I tested with my user, another colleague user. So I assume the problem is not logged user. I inserted the field "votes.asCounts" it doesn't count anything.
I don't know what might be happening with something so simple as setting a voting control!?
Source code here:
<ac:structured-macro ac:macro-id="31980d4b-28f9-421f-a99a-230dd0c159d2" ac:name="confiform" ac:schema-version="1">
<ac:parameter ac:name="formName">voting</ac:parameter>
<ac:rich-text-body>
<p>
<ac:structured-macro ac:macro-id="0b30486c-0e45-4bc5-89a8-96c5238aa8a4" ac:name="confiform-field-definition" ac:schema-version="1">
<ac:parameter ac:name="fieldName">choice1</ac:parameter>
<ac:parameter ac:name="fieldLabel">Choice 1</ac:parameter>
<ac:parameter ac:name="type">text</ac:parameter>
<ac:parameter ac:name="required">true</ac:parameter>
</ac:structured-macro>
</p>
<p>
<ac:structured-macro ac:macro-id="0221e7b7-2d3e-4791-9e44-1ed5a8bf314e" ac:name="confiform-field-definition" ac:schema-version="1">
<ac:parameter ac:name="fieldName">votes</ac:parameter>
<ac:parameter ac:name="fieldLabel">Vote!</ac:parameter>
<ac:parameter ac:name="values">Vote for me!</ac:parameter>
<ac:parameter ac:name="extras">Remove my vote</ac:parameter>
<ac:parameter ac:name="type">voting</ac:parameter>
</p>
<p>
<ac:structured-macro ac:macro-id="34586145-846a-47a7-b52a-b0a13ad6eb78" ac:name="confiform-field" ac:schema-version="1">
<ac:parameter ac:name="fieldName">votes.asCounts</ac:parameter>
</p>
<ac:structured-macro ac:macro-id="31c1c027-878e-4357-9ca6-4c099db47435" ac:name="confiform-entry-register" ac:schema-version="1">
<ac:parameter ac:name="atlassian-macro-output-type">INLINE</ac:parameter>
<ac:rich-text-body>
<p>
<br/>
</p>
</ac:rich-text-body>
<p class="auto-cursor-target">
<br/>
</p>
<br/>
<ac:structured-macro ac:macro-id="35c85711-cee2-47eb-ac05-4ebf6c8c30af" ac:name="confiform-table" ac:schema-version="1">
<ac:rich-text-body>
<p>
<br/>
</p>
Alex Medved _ConfiForms_
May 18, 2022 edited
Hi
There is no such function as "asCounts", but there is a function called "asCount" that you can use
So, the expression should be votes.asCount
And the ConfiForms Field needs to be used from within view macro, ie in TableView in current case
Please note that voting control works only for authenticated users
Alex
karina ospina May 18, 2022 edited
Hey Alex!
Thanks for your kind help. I corrected the typo, it doesn't work ...
>When I click on vote button it doesn't count the vote. I am logged in.
Here the source code:
<ac:rich-text-body>
<p>
</p>
<p>
<ac:structured-macro ac:macro-id="5f53e847-762f-4919-b9bb-051799125597" ac:name="confiform-field-definition" ac:schema-version="1">
</p>
<p>
<ac:structured-macro ac:macro-id="a1788284-ffe8-42ef-a3b4-0ba9056e0b6a" ac:name="confiform-field" ac:schema-version="1">
<ac:parameter ac:name="fieldName">votes.asCount</ac:parameter>
</p>
<ac:rich-text-body>
<p>
<br/>
</p>
<br/>
</p>
<br/>
</p>
<ac:rich-text-body>
<p>
<br/>
</p>
Hi Alex!
Thanks for your kind help. After correcting the typo "as.Counts" it is still not working. The vote button doesn't change the counter.  (I am logged in)
<ac:rich-text-body>
<p>
</p>
<p>
</p>
<p>
</p>
<ac:rich-text-body>
<p>
<br/>
</p>
<br/>
</p>
<br/>
</p>
<ac:rich-text-body>
<p>
<br/>
</p>
AND
when I put the field "votes.asCount" inside tableview, the vote button is gone.
Here source code for that:
<ac:rich-text-body>
<p>
</p>
<p>
</p>
<p>
<br/>
</p>
<ac:rich-text-body>
<p>
<br/>
</p>
<br/>
</p>
<br/>
</p>
<ac:rich-text-body>
<p>
</p>
Hey Alex!
Thanks again for your support!. After you sharing the screencast with my code on your confluence environment and me trying the same on my company confluence setup, I conclude it can onle be some sysadmin setup that prevents me to use the confiform voting control.
I corrected what you suggested, and use exactly the same macros in the order you suggested in the video, AND it doesn't work...
Here source code:
<ac:rich-text-body>
<p>
</p>
<p>
</p>
<p>
<br/>
</p>
<ac:rich-text-body>
<p>
<br/>
</p>
<br/>
</p>
<br/>
</p>
<ac:rich-text-body>
<p>
<ac:structured-macro ac:macro-id="63c80c14-44e0-4ac0-98b3-4414b156b79f" ac:name="confiform-field" ac:schema-version="1">
</p>
<p>
<ac:structured-macro ac:macro-id="262ae748-8dd2-457f-869e-c42b25116226" ac:name="confiform-field" ac:schema-version="1">
</p>
