Configure the help menu
Thor Henrik Nordvik October 18, 2019
Hi
I have recently taken responsibility over an Confluence site.
They have changed the help menu, added links to internal pages.
This page have been deleted, so now I need to change the menu.
How can I change this
Nicolai Sibler
October 18, 2019
Hi Thor Henrik,
maybe the changes to the help menu have been made with custom HTML.
Check out Admin → Look and Feel → Custom HTML → At end of the BODY. If you find the outdated links there, just delete the very code lines and save.
Best regards,
Nicolai
PVS
Banned
October 18, 2019
Hallo @Thor Henrik Nordvik
Follow The Link It's Helps To You More,
by adding a plugin:
https://developer.atlassian.com/display/CONFDEV/Adding+an+Option+to+the+Editor+Insert+Menu
I hope this helps. :)
