Confluence 6.15.9 installer is not running
Navam Rajput
I am trying to upgrade the Confluence from 6.15.4 to 6.15.9 , whenever I tried to execute the installer using command in the folder containing the executable installer
sudo ./atlassian-confluence-6.15.9.x-64.bin , it just freeze up , showing nothing since 30 minutes and log files  is showing nothing after the confluence is terminated (stop) , which I assume nothing is working after it.
Kiran Panduga {Appfire}
Hi @Navam Rajput ,
Can you look at the available system resources (Memory, CPU usage ) and try to release any cache memory.
can you look if any process with "java" or "confluence" running ? using
ps -ef |grep -i java
Can you also set the permission for the installer to 755 i.e
chmod 755 atlassian-confluence-6.15.9.x-64.bin
Kiran
