Confluence 6 won't start editor
Anton
November 15, 2016
When I install fresh copy of Confluence 6.0.1 and create space, I can't add enything else becouse editor won't load. When i clik on 'Create' button I get red hint 'Loading the editor's taking longer than usual. Give it a few moments, then refresh your page if it still doesn't load. Speak to your Confluence admin if that doesn't fix it'.
When I first time install Confluence it was with free licence and H2 databse everithing works fine. Then I purchace licence and install fresh copy on new VPS with Mysql 5.6. OS is Centos 7 x64 with 8Gb ram.
I try almost everthing with no success. Reinstall Confluence few times with restore old data and without restore.
Also I do the same for JIRA and everthing works fine.
After recheck all premissions on folders and database I dont have a clue what to check next. Logs don't show any errors.
Any suggestion ?
Dragan
Anton
November 15, 2016
As I expect, solution was in configuration. I installed JIRA first and use it as user manager for Confluence, So when i enable option 'External user management' in Security Configuration of Confluence everything works fine.
Markus Zimmermann
November 17, 2016
I just installed Confluence (Linux Ubuntu 16.10) and created my first space, the editor however doesn't load and a message is displayed:
"Loading the editor's taking longer than usual. Give it a few moments, then refresh your page if it still doesn't load. Speak to your Confluence admin if that doesn't fix it."
I suppose that is what happened to you too? I also had installed JIRA Software first and then Confluence, with JIRA managing users and groups, I enabled the option also in Confluence "external user management" - but still the same issue. sad
RIP Confluence, I guess
12 votes
Richard Freitag
December 22, 2016
I had the same problem and the solution was to deactivate the new collaborative editing feature that seems to be swallowed by some firewalls. If you do not need the feature, go to Admin --> General Configuration --> Collaborative Editing and deactivate it. If you need the features, look at the following page on how to fix it: https://answers.atlassian.com/questions/43893571
jwcrawford
June 7, 2018
Thanks, disabling collaborative editing solved this issue for me:
tmotal
October 20, 2018
Had the same issue with Confluence 6.12.0. Deactivating the collaborative editing feature helped. The whole application became instantly faster - much faster.
Thanks for the tip! Still valid in 2018 :)
marcela furyova
March 1, 2019
Hi all, deactivate Collaborative Editing helps.
Thanks.
marcela
rgolebiewski
July 7, 2019
Disabling of Collaborative Editing worked perfectly for me (I lost so many hours trying to figure it out why). Thank you very much!
Raphael Aubin May 17, 2018
For Confluence 6.9.0
For my part, I host Confluence on my server and it installed with localhost as Server Base URL (under General Configuration\General Configuration)
When using Confluence outside the server, i've got the error, so to fix the problem, I've just updated the Server Base URL with the public URL and it fix the issue.
Mike Pickard July 5, 2017
After updating to Confluence 6.2.3, I had to go into General Configuration --> Administration --> Collaborative Editing and change Editing Mode to Off in order for users to edit any page.
Definately a problem with Collaborative editing and the use of Synchrony.
Erkki_Aalto
April 18, 2017
It is the collaborative editing. You should be able to make it to work with e.g. these proxy settings:
ProxyPass /synchrony-proxy http://localhost:8090/synchrony-proxy
<Location /synchrony-proxy>
Require all granted
RewriteEngine on
RewriteCond %{HTTP:UPGRADE} ^WebSocket$ [NC]
RewriteCond %{HTTP:CONNECTION} Upgrade$ [NC]
RewriteRule .* ws://localhost:8090%{REQUEST_URI} [P]
</Location>
This works even when you use ajp-proxy for everything else.
