Confluence Autoconvert JIRA links
Kim Wall
Hello!
I'm currently evaluating Confluence and am running into an issue with Autoconvert. It seems to work for things like Google Maps, but when I paste a link to a JIRA issue (my JIRA instance or even one from jira.atlassian.com) it does nothing.
I've checked the plugin and all modules are enabled.
Any thoughts?
Giuliano C_
September 26, 2012
I'm not sure, but maybe you're experiencing a communication problem. If that's the case, you need to import the certificates into both the Jira and Confluence cert stores so that they can both communicate with each other.You will need to do this due to accessing the Jira issue via https. Please, refer to the following documentation, it could help you to solve this problem, if that is the case:
https://confluence.atlassian.com/display/JIRA/Connecting+to+SSL+services
Hope it helps!
Kind Regards
Kim Wall
I saw that, too, but since my current test environments for both JIRA and Confluence are not using HTTPS, would this be a factor? In production everything we have will be SSL, so this will definitely come into play, but should it matter if we're just using HTTPS?
Kim
atlassian, confluence whiteboards, whiteboard templates, template contest, visual collaboration, atlassian learning, confluence community, brainstorming tools, agile planning, team productivity, confluence templates, share your template
Share Your Confluence Whiteboard Template for a Chance to Be Featured in the Product! 🏆
Want to leave your mark on Confluence? One winner will have their whiteboard design added into Confluence for all users to access! This is your chance to showcase your creativity, help others, and gain recognition in the Confluence community.
Share your template today!
