Confluence Cannot Load More Than 100 Records (via Insight Objects Macro for Confluence)
Vincenzo Ciaravella October 22, 2021
When I change my "Load Limit" from 100 to either 500 or 1000 records, via the Insight Objects Macro for Confluence, for a Confluence page, the page loads/cycles endlessly.
We are then forced to abort the process (i.e. refresh page, edit then return back to our original 100 load limit parameter).
In the use case that I timed, I was well over 5 minutes before having to abort.
Included are a couple of screen shots.
Vince
Fabian Lim
October 22, 2021
Hi @Vincenzo Ciaravella
Another option you have is with a third party app, unless Atlassian decides to fix the many issues this macro has.
We use insight with eazyBI for reporting, where you can then take the insight report and use it as a macro in confluence.
Regards.
