I'm trying to follow the Create a Confluence 'Hello World' Macro tutorial but upon reaching the 'Create a Macro Element in Confluence' step, my helloworld macro fails to appear in the macro browser.
From the tutorial, the atlassian-plugin.xml was updated to include xhtml-macro tag:
<xhtml-macro name="helloworld" class="com.atlassian.tutorial.macro.helloworld" key='helloworld-macro'>
<description key="helloworld.macro.desc"/>
<category name="formatting"/>
<parameters/>
</xhtml-macro>
The properties for the plugin were updated:
#put any key/value pairs here
my.plugin.name=MyPlugin
helloworld.macro.desc="Hello World"
I also added the helloworld.java file in /src/main/java/com/atlassian/tutorial/macro:
package com.atlassian.tutorial.macro;
import com.atlassian.confluence.content.render.xhtml.ConversionContext;
import com.atlassian.confluence.macro.Macro;
import com.atlassian.confluence.macro.MacroExecutionException;
import java.util.Map;
public class helloworld implements Macro {
public String execute(Map<String, String> map, String s, ConversionContext conversionContext) throws MacroExecutionException {
return "<h1>Hello World!</h1><h2>Test</h2>";
public BodyType getBodyType() { return BodyType.NONE; }
public OutputType getOutputType() { return OutputType.BLOCK; }
Eventually I tried pulling the source code from bitbucket. I'd made a simple mistake and added the xhtml-macro tag as a child of the web-resource tag instead of after it:
<web-resource key="myConfluenceMacro-resources" name="myConfluenceMacro Web Resources">
<dependency>com.atlassian.auiplugin:ajs</dependency>
<resource type="download" name="myConfluenceMacro.css" location="/css/myConfluenceMacro.css"/>
<resource type="download" name="myConfluenceMacro.js" location="/js/myConfluenceMacro.js"/>
<resource type="download" name="images/" location="/images"/>
<context>myConfluenceMacro</context>
<xhtml-macro name="helloworld" class="com.atlassian.tutorial.macro.helloworld" key='helloworld-macro' hidden="false">
<parameters />
</xhtml-macro>
</web-resource>
</web-resource>
<parameters />
</xhtml-macro>
Maybe the instruction "Locate the end of the <web-resource>...</web-resource> section in the file and enter the following:" should be updated to say "Locate the end of the <web-resource>...</web-resource> section in the file and enter the following after the closing web-resource tag"?
Hopefully this helps others going forward!
great answer, save me time.
rrr, did exactly the same thing ...
Thanks a lot!
It saved me the evaning! I was desperate.!
Same problem here three years later. Tutorial is very unclear:
How about "Locate the end of the <web-resource>...</web-resource> section in the file and insert the following after:"
or even...
"Locate the </atlassian-plugin> end tag and insert the following just before it:"
Same problem here. But also having problems, in general, getting the macro to appear.
it's the bad you haven't change that in the tutorial and all newcomer gat the same f** problem with in (((
Help us plant more trees
