×Hello,
I am looking to use SSO in OpenID Connect mode with Keycloak. The configuration is correct, when I perform a test it works perfectly.
But problem being that in the login page I don't have the option to connect via my Identity Provider. Do you have an idea ?
I would like to point out that I performed the same configuration on a Jira Server, I have no worries.
My Confluence server version is 7.15.1
Hi Alexis,
I am Ashwini, part of the team of Confluence OAuth SSO Addon mentioned in the above comment.
Thanks, @Pramodh M for suggesting our app!
Confluence OAuth SSO app will allow you to login in Confluence using Keycloak. You can also update user-profiles and groups from the keycloak.
You can evaluate the app free from the marketplace. Please raise a ticket here for a free consultation to set up the app on your confluence instance.
Ashwini
Welcome to Confluence
You could try setting up it with manageable add-ons from the marketplace
Pramodh
