Confluence PostgreSQL JDBC direct connection refused
Nicolas Lapaire October 9, 2017 edited
Hi all,
When I try to test the database connection, I have the following error :
Can't reach database server or port
SQLState - 08001
org.postgresql.util.PSQLException: Connection to localhost:5432 refused. Check that the hostname and port are correct and that the postmaster is accepting TCP/IP connections.
The postgresql.conf file looks like :
# - Connection Settings -
listen_addresses = '*' # what IP address(es) to listen on;
# comma-separated list of addresses;
# defaults to 'localhost', '*' = all
# (change requires restart)
port = 5432 # (change requires restart)
max_connections = 100 # (change requires restart)
The pg_hba.conf file looks like :
# TYPE DATABASE USER CIDR-ADDRESS METHOD
# "local" is for Unix domain socket connections only
local all all trust
# IPv4 local connections:
host all all 127.0.0.1/32 trust
# IPv6 local connections:
host all all ::1/128 ident
host all all localhost/24 trust
The PostgreSQL service is running.
I tried also to disable the firewall and the antivirus.....without success.
What should I try more ?
Thanks in advance for your precious help
Windows 7 / confluence installed on the same computer as PostgreSQL 10
Windows 7 / Confluence installed on the same computer as PostgreSQL10
AnnWorley
October 9, 2017
It sounds like you saw Confluence PostgreSQL JDBC direct connection refused. Please double check that PostgreSQL was restarted after the authentication was set to trust instead of ident.
On a side note, I don't think this is the cause of the issue but PostgreSQL ver. 10 is not a supported platform for Confluence 6.4.x: Supported Platforms
Nicolas Lapaire October 24, 2017
I just had to change the port. The default port was 5434.
Everything works fine right now.
Thank you for your help :-)
Please, how can I close the questions ?
Nic Brough -Adaptavist-
October 24, 2017
Mark an answer as "correct".  There's a tick mark (and voting box) next to every answer.
Thank you
Like • Xavi likes this
