Confluence Questions Page not found
Nathan Hamar January 28, 2015
We just purchased and installed Confluence Questions 1.1.47 into our Confluence instance (5.6.5) and when I click the "Questions" link in the top navigation, I get a page not found error instead of the confluence questions interface. The link points to http://ourconfluenceinstancename:8090/questions so the link appears to be correct.
I don't see any configuration options in the add-on manager and the installation instructions just say to click install so I'm not sure what I missed.
Deividi Luvison
January 29, 2015
That is totally strange, usually confluence questions behave like that when we deal with instances that when trough a xml restoration process.
Before raising the case can you try the following:
  1. Un install Confluence questions.
  2. Go to Confluence Admin > General Configuration.
  3. Check if the base URL you are using matches with the one you are using into your browser.
  4. Now follow the steps of the Clear Confluence Plugin Cache guide.
  5. Once Confluence is up try re installing the plugin.
  6. If it still fails then raise a case to us and also mention this answer so we can be aware of the steps you tried.
Thanks and Regards,
David| The Engineer that like Windows for realsies.
john
January 28, 2015
Hey @Nathan Hamar - sorry to hear about this. Can you please raise a support ticket and provide these details to them? You can raise a support ticket here: https://support.atlassian.com/secure/Dashboard.jspa
atlassian, atlassian community, job interviews, interview tips, career advice, interview preparation, job search, interview experiences, hiring process, atlassian careers, community discussion, interview best practices
Interview Tips & Pet Peeves ✍️
Join the discussion on interview best practices and common pitfalls. Share your experiences and learn from others in the Atlassian Community.
Share you experiences!
