Confluence: Solving / Archiving an article
Dieter Loskarn
February 11, 2014
Is there a way to mark an article as solved / archived so the topic is shown greyed out in the navigation?
Midori
July 21, 2015
Add the label "archive" (or "archive-single") to the article, and let the Archiving Plugin move it to an archive space.
That way it disappears from the original space, from the regular searches, etc., but you can still view this, restore this, from the archive space.
William Zanchet [Atlassian]
February 17, 2014
Hi Dieter,
Actually, we don't have such feature that would perform it. However, you could use the tasklist macro feature, which will give you a check box:
https://confluence.atlassian.com/display/DOC/Tasklist+Macro
Hope this helps.
WZ
