Hi all,
We've the setup as stated in the subject: Confluence is running on Windows Server, behind IIS configured as described in http://confluence.atlassian.com/display/DOC/Setting+up+Confluence+with+IIS for use with WebDAV, I installed the WebDAV handler. When installing Team Calendars and try to access the calendar an error occurs, with Firebug I see the following:
According to several documentation I found out that the webDAV module feels responsible for the DELETE request and this doesn't work. According to several forum posts, you should disable WebDAV for this application:
http://forums.iis.net/t/1176772.aspx
http://forums.iis.net/t/1166025.aspx
You'll find many more entries: http://bit.ly/plBiI0
One question, I tried to remove WebDAV but it didn't help, do I loose WebDAV support within Confluence, then? Has anyone else an idea how to tackle this problem?
