Confluence Wont start !!!
testdockerhub
hello,
i just installed Confluence 6.13.1 on New Centos7 instance, installation process was perfect..,once installation completed.,i get the URL to complete configuration of my confluence on the webbrowser and as i choosed the default port ,it was something like (localhost:8090) .
and here i had nothing to be displayed on the browser .i tried Curl localhost:8090...and there was no result back as well .
was there something wrong !!! did i missed a step !!! should i configure somethign else !!!!
Yogesh Mude
January 31, 2019
HI @testdockerhub
Actually it will take time to load at first time and check with telnet and wget <confluence_url>.
Please check the log files as well...you will find those in <Confluence_home>/log/atlassian-confluence.log and <confluence_installation>/logs/catalina.out file.
testdockerhub
thanks @Yogesh Mude  for your answer, but im not sure about that because i started the installation yesterday and now after 24h the instance still does not reply.
( SElinux is disabled and there is no FirewalldD )
Any solution !!!!
testdockerhub
finally there was the Port 8090 Blocked at the firewall Level .
thanks
Register now
