Confluence compatibility with JIRA
santosh srirangam November 17, 2015
We have JIRA 6.3.11 version running in our organization. Now we would like to install Confluence.
Do we have a version compatibility issues with JIRA and Confluence.
Or can someone suggest which version of confluence is compatible with JIRA 6.3.11
Santosh.
Jobin Kuruvilla [Adaptavist]
November 17, 2015
There is no version compatibility, although very old Confluence versions will lack some integration features. I would go with the latest Confluence version.
Nic Brough -Adaptavist-
November 17, 2015
Same here. You'll generally find anything from Confluence 4.0 to 5.9 will work ok with Jira 6.x, but as Jobin says, I'd go with the latest because the integration offers the most options, and it's the best version yet.
Bruno Raymundo
November 17, 2015
Hi Santosh,
Just make sure, as well, that you check the supported platforms for both products:
Bruno
Vera Henrichs
November 17, 2015
Indeed, when you just make sure you have the latest or later versions, there won't be a compatibility-problem.
