Confluence connection timeout
Alexandre May 5, 2014
Hi !
I try to make a manual backup for confluence.
So, I copy my home directory and make a dump of my database.
When I restore all datas on an another confluence (which is a test server), I can't login with admin or others users.
I get this error :
The host did not accept the connection within timeout of 5000 ms
Logs :
2014-05-06 11:35:37,278 ERROR [http-8090-9] [crowd.manager.application.ApplicationServiceGeneric] authenticateUser Directory 'JIRA Server' is not functional during authentication of 'admin'. Skipped.
2014-05-06 11:35:37,282 WARN [http-8090-9] [atlassian.confluence.user.ConfluenceAuthenticator] authenticate OperationFailedException caught while authenticating user <admin>.
com.atlassian.crowd.exception.runtime.OperationFailedException
at com.atlassian.crowd.embedded.core.CrowdServiceImpl.convertOperationFailedException(CrowdServiceImpl.java:869)
at com.atlassian.crowd.embedded.core.CrowdServiceImpl.authenticate(CrowdServiceImpl.java:79)
at com.atlassian.crowd.embedded.atlassianuser.EmbeddedCrowdAuthenticator.authenticate(EmbeddedCrowdAuthenticator.java:30)
at bucket.user.DefaultUserAccessor.authenticate(DefaultUserAccessor.java:592)
at sun.reflect.GeneratedMethodAccessor773.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:307)
at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:182)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:149)
at com.atlassian.spring.interceptors.SpringProfilingInterceptor.invoke(SpringProfilingInterceptor.java:16)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:171)
at org.springframework.transaction.interceptor.TransactionInterceptor.invoke(TransactionInterceptor.java:106)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:204)
at $Proxy31.authenticate(Unknown Source)
at com.atlassian.confluence.user.ConfluenceAuthenticator.authenticate(ConfluenceAuthenticator.java:65)
at com.atlassian.seraph.auth.DefaultAuthenticator.login(DefaultAuthenticator.java:94)
at com.atlassian.confluence.user.ConfluenceAuthenticator.login(ConfluenceAuthenticator.java:47)
at com.atlassian.seraph.filter.PasswordBasedLoginFilter.runAuthentication(PasswordBasedLoginFilter.java:127)
at com.atlassian.seraph.filter.PasswordBasedLoginFilter.login(PasswordBasedLoginFilter.java:72)
at com.atlassian.seraph.filter.BaseLoginFilter.doFilter(BaseLoginFilter.java:130)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:46)
at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:66)
at com.atlassian.oauth.serviceprovider.internal.servlet.OAuthFilter.doFilter(OAuthFilter.java:71)
at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:74)
at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42)
at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:77)
at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:63)
at com.atlassian.confluence.util.ClusterHeaderFilter.doFilter(ClusterHeaderFilter.java:37)
at com.atlassian.johnson.filters.AbstractJohnsonFilter.doFilter(AbstractJohnsonFilter.java:72)
at org.springframework.orm.hibernate.support.OpenSessionInViewFilter.doFilterInternal(OpenSessionInViewFilter.java:170)
at com.atlassian.spring.filter.FlushingSpringSessionInViewFilter.doFilterInternal(FlushingSpringSessionInViewFilter.java:29)
at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:76)
at com.atlassian.confluence.util.ConfluenceErrorFilter.doFilter(ConfluenceErrorFilter.java:22)
at com.atlassian.util.profiling.filters.ProfilingFilter.doFilter(ProfilingFilter.java:99)
at com.atlassian.confluence.core.datetime.RequestTimeThreadLocalFilter.doFilter(RequestTimeThreadLocalFilter.java:35)
at com.atlassian.gzipfilter.GzipFilter.doFilterInternal(GzipFilter.java:80)
at com.atlassian.gzipfilter.GzipFilter.doFilter(GzipFilter.java:51)
at com.atlassian.core.filters.cache.AbstractCachingFilter.doFilter(AbstractCachingFilter.java:33)
at com.atlassian.core.filters.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:31)
at com.atlassian.confluence.extra.webdav.servlet.filter.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:427)
at com.atlassian.confluence.extra.webdav.servlet.filter.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:34)
at com.atlassian.confluence.web.filter.validateparam.RequestParamValidationFilter.doFilter(RequestParamValidationFilter.java:58)
at com.atlassian.confluence.web.filter.TranslationModeFilter.doFilter(TranslationModeFilter.java:43)
at com.atlassian.confluence.plugin.servlet.filter.ActionContextCleanUp.doFilter(ActionContextCleanUp.java:71)
at com.atlassian.confluence.web.filter.LanguageExtractionFilter.doFilter(LanguageExtractionFilter.java:54)
at com.atlassian.confluence.util.RequestCacheThreadLocalFilter.doFilter(RequestCacheThreadLocalFilter.java:25)
at com.atlassian.core.filters.encoding.AbstractEncodingFilter.doFilter(AbstractEncodingFilter.java:41)
at com.atlassian.core.filters.HeaderSanitisingFilter.doFilter(HeaderSanitisingFilter.java:44)
at com.atlassian.confluence.servlet.FourOhFourErrorLoggingFilter.doFilter(FourOhFourErrorLoggingFilter.java:65)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:298)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:859)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:588)
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:489)
at java.lang.Thread.run(Unknown Source)
Caused by: org.apache.commons.httpclient.ConnectTimeoutException: The host did not accept the connection within timeout of 5000 ms
at org.apache.commons.httpclient.protocol.ReflectionSocketFactory.createSocket(ReflectionSocketFactory.java:155)
at org.apache.commons.httpclient.protocol.DefaultProtocolSocketFactory.createSocket(DefaultProtocolSocketFactory.java:125)
at org.apache.commons.httpclient.HttpConnection.open(HttpConnection.java:707)
at org.apache.commons.httpclient.MultiThreadedHttpConnectionManager$HttpConnectionAdapter.open(MultiThreadedHttpConnectionManager.java:1361)
at org.apache.commons.httpclient.HttpMethodDirector.executeWithRetry(HttpMethodDirector.java:387)
at org.apache.commons.httpclient.HttpMethodDirector.executeMethod(HttpMethodDirector.java:171)
at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:397)
at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:323)
at com.atlassian.crowd.integration.rest.service.RestExecutor$MethodExecutor.executeCrowdServiceMethod(RestExecutor.java:420)
at com.atlassian.crowd.integration.rest.service.RestExecutor$MethodExecutor.andReceive(RestExecutor.java:309)
at com.atlassian.crowd.integration.rest.service.RestCrowdClient.authenticateUser(RestCrowdClient.java:114)
at com.atlassian.crowd.directory.RemoteCrowdDirectory.authenticate(RemoteCrowdDirectory.java:146)
at com.atlassian.crowd.directory.DbCachingRemoteDirectory.authenticateAndEnsureInternalUserExists(DbCachingRemoteDirectory.java:205)
at com.atlassian.crowd.directory.DbCachingRemoteDirectory.authenticate(DbCachingRemoteDirectory.java:111)
at com.atlassian.crowd.manager.directory.DirectoryManagerGeneric.authenticateUser(DirectoryManagerGeneric.java:277)
at com.atlassian.crowd.manager.application.ApplicationServiceGeneric.authenticateUser(ApplicationServiceGeneric.java:122)
at com.atlassian.crowd.embedded.core.CrowdServiceImpl.authenticate(CrowdServiceImpl.java:67)
... 107 more
Caused by: java.net.SocketTimeoutException: connect timed out
at java.net.PlainSocketImpl.socketConnect(Native Method)
at java.net.PlainSocketImpl.doConnect(Unknown Source)
at java.net.PlainSocketImpl.connectToAddress(Unknown Source)
at java.net.PlainSocketImpl.connect(Unknown Source)
at java.net.SocksSocketImpl.connect(Unknown Source)
at java.net.Socket.connect(Unknown Source)
at sun.reflect.GeneratedMethodAccessor759.invoke(Unknown Source)
at org.apache.commons.httpclient.protocol.ReflectionSocketFactory.createSocket(ReflectionSocketFactory.java:140)
... 123 more
On which server confluence want to connect ?
The authentication works before I restore data.
Thanks !
I am taking a look.
Thanks !
Nic Brough -Adaptavist-
May 5, 2014
It looks like the source Confluence is configured to connect to a Jira system to get its user data.
When you've restored it, the test system is trying the same connection, but being refused.
I can't be 100% sure that's the case, so I'd start with a look at the production Confluence - see how its user directories are configured, then have a look at the actual directory server and check it's happy to get receive connections from your test system as well.
In my database (MySql), I have all users with "nopass" for the password, is it normal if I need to connect to a Jira system ?
May 5, 2014
I don't think that matters if you're connecting to a Jira database. You need to establish that first.
Can I connect my confluence with the other Jira database ?
Or I need to install Jira and backup it too ?
If I can connect my confluence with the other Jira database, how can I make this without the administrator account ? (I tried to modify the password with atlassian documentation but I can't log me in with ...)
May 5, 2014
We don't know enough about your configuration to answer that.
A confluence set up to use a Jira for its user database is only read-only, so it can't do any harm to set it up, but we can't really tell you about your configuration. Have a read through https://confluence.atlassian.com/display/DOC/Integrating+JIRA+and+Confluenceto get started.
