Confluence docker setup problems
admin May 1, 2019 edited
I am running an confluence docker on my local macOS with the Trial DB option. It is a flesh installation.
I cannot enter the edit page when I click the "Create" button.Screenshot 2019-05-02 at 11.09.52 AM.png
REFERENCE:
docker image atlassian/confluence-server
https://hub.docker.com/r/atlassian/confluence-server/
image: atlassian/confluence-server:6.15-ubuntu-18.04-adoptopenjdk8
version: '3.5'services: confluence-serv: image: atlassian/confluence-server:6.15-ubuntu-18.04-adoptopenjdk8 environment: - CATALINA_CONNECTOR_PROXYNAME=${VIRTUAL_HOST} - CATALINA_CONNECTOR_PROXYPORT=8090 - CATALINA_CONNECTOR_SCHEME=http - CATALINA_CONNECTOR_SECURE=false - CATALINA_CONTEXT_PATH=confluence restart: always ports: - "8090:8090" - "8091:8091" volumes: - ${HOME_PATH}:/var/atlassian/application-data/confluence
sara
May 1, 2019
From first impression.
1.The page loading is failing because synchrony service is failing.You can turn off collaborative editing(admin section confluence) and page creation/saving will work.
2.It might be failing because you have to set the synchrony base url path in setenv.sh.
admin May 1, 2019
I found collaborative editing is under good status but you are right. The page creation/saving is working after turn off the editing mode. Thank you.
admin May 2, 2019
I have one more question. The Collaborative editing cannot be disabled at the console UI under HTTPS.
Can I deactivate it by changing some conf file?
sara
May 5, 2019
Hey wayne,
You can disable this by change mode and turn off.
Warning:Tuning off CE will delete all stale drafts and this will take time(keeps on loading).Also depends on version of confluence
https://jira.atlassian.com/browse/CONFSERVER-55745
https://jira.atlassian.com/browse/CONFSERVER-57697
admin May 5, 2019
Thank you.
I changed to a new domain name and disable the CE at the UI under HTTP.
sara
May 6, 2019
Hey wayne,
have you set up confluence DC in docker setup.
If yes how you achieved it?
admin May 6, 2019
Unfortunately, it is not success yet. Using confluence DC in docker setup is perfectly fine with HTTP request. However, when I turn on the HTTPS, there are lots of problems to solve.
The first one is collaborative editing, which can be solved by turning off the collaborative editing. Cloud we said that it is solved....
The second one is POST request to rest api which is not solved yet. This affects the image insert and saving draft. Edit, Create and Save post works well without solving this.
My structure is using nginx-proxy container as the nginx gateway, it uses the upstream to communicate with confluence container with customized conf.
There are many choice for the nginx-proxy. I am currently using this one. https://github.com/jwilder/nginx-proxy
sara
May 6, 2019
Ok.I was successful in setting up one container in one host.But my intention is to setup multiple confluence DC containers in different hosts.Looking a way for it .Any thoughts?
admin May 6, 2019
I just used the official image which completes everything for me.
Definitely, I am not there yet. I have checked this guide.
https://confluence.atlassian.com/doc/installing-confluence-data-center-203603.html
It requires the files on <installation directory>/confluence/WEB-INF/classes/confluence-init.properties where installation directory is /opt/atlassian/confluence
Though, I have tried to mount this path to host which is not success...
atlassian, confluence whiteboards, whiteboard templates, template contest, visual collaboration, atlassian learning, confluence community, brainstorming tools, agile planning, team productivity, confluence templates, share your template
Share Your Confluence Whiteboard Template for a Chance to Be Featured in the Product! 🏆
Want to leave your mark on Confluence? One winner will have their whiteboard design added into Confluence for all users to access! This is your chance to showcase your creativity, help others, and gain recognition in the Confluence community.
Share your template today!
