I am trying to upgrade confluence from 5.1.4 TO 5.4.3. I have confluence 5.1.4 running on Tomcat 6. Before, i actually do the upgrade, I wanted to test it on the my test-server. I installed confluence 5.4.3 version. I made a copy of existing database in mysql and confluence home_directory, and linked with the new version 5.4.3. I followed the steps from the attlassian guideline provided online but, i cant find the solutioin for the following error;
when i start the tomcat server, i am getting the following error;
Mar 06, 2014 8:36:02 PM org.apache.coyote.http11.Http11Protocol pause
INFO: Pausing Coyote HTTP/1.1 on http-8089
Mar 06, 2014 8:36:03 PM org.apache.catalina.core.StandardService stop
INFO: Stopping service Catalina
Mar 06, 2014 8:36:03 PM org.apache.coyote.http11.Http11Protocol destroy
INFO: Stopping Coyote HTTP/1.1 on http-8089
Mar 06, 2014 8:36:05 PM org.apache.catalina.startup.ClassLoaderFactory validateFile
WARNING: Problem with directory [/var/lib/tomcat6/common/classes], exists: [false], isDirectory: [false], canRead: [false]
WARNING: Problem with directory [/var/lib/tomcat6/common], exists: [false], isDirectory: [false], canRead: [false]
WARNING: Problem with directory [/usr/share/tomcat6/server/classes], exists: [false], isDirectory: [false], canRead: [false]
WARNING: Problem with directory [/usr/share/tomcat6/server], exists: [false], isDirectory: [false], canRead: [false]
WARNING: Problem with directory [/var/lib/tomcat6/server/classes], exists: [false], isDirectory: [false], canRead: [false]
WARNING: Problem with directory [/var/lib/tomcat6/server], exists: [false], isDirectory: [false], canRead: [false]
WARNING: Problem with directory [/usr/share/tomcat6/shared/classes], exists: [false], isDirectory: [false], canRead: [false]
WARNING: Problem with directory [/usr/share/tomcat6/shared], exists: [false], isDirectory: [false], canRead: [false]
WARNING: Problem with directory [/var/lib/tomcat6/shared/classes], exists: [false], isDirectory: [false], canRead: [false]
WARNING: Problem with directory [/var/lib/tomcat6/shared], exists: [false], isDirectory: [false], canRead: [false]
Mar 06, 2014 8:36:06 PM org.apache.coyote.http11.Http11Protocol init
INFO: Initializing Coyote HTTP/1.1 on http-8089
Mar 06, 2014 8:36:06 PM org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 624 ms
Mar 06, 2014 8:36:06 PM org.apache.catalina.core.StandardService start
INFO: Starting service Catalina
Mar 06, 2014 8:36:06 PM org.apache.catalina.core.StandardEngine start
INFO: Starting Servlet Engine: Apache Tomcat/6.0.35
Mar 06, 2014 8:36:06 PM org.apache.catalina.startup.HostConfig deployDescriptor
INFO: Deploying configuration descriptor confluence-test.xml
2014-03-06 20:36:08,075 INFO [main] [com.atlassian.confluence.lifecycle] contextInitialized Starting Confluence 5.4.3 [build 4732 based on commit hash f543bd9a3bbc12daed85f6f5e5cba84282599932]
Mar 06, 2014 8:36:12 PM org.apache.catalina.core.StandardContext start
SEVERE: Error listenerStart
SEVERE: Context [/confluence-test] startup failed due to previous errors
log4j:ERROR LogMananger.repositorySelector was null likely due to error in class reloading, using NOPLoggerRepository.
Mar 06, 2014 8:36:12 PM org.apache.catalina.startup.HostConfig deployDescriptor
INFO: Deploying configuration descriptor probe5.xml
Mar 06, 2014 8:36:17 PM org.apache.coyote.http11.Http11Protocol start
INFO: Starting Coyote HTTP/1.1 on http-8089
Mar 06, 2014 8:36:17 PM org.apache.jk.common.ChannelSocket init
INFO: JK: ajp13 listening on /0.0.0.0:8019
Mar 06, 2014 8:36:17 PM org.apache.jk.server.JkMain start
INFO: Jk running ID=0 time=0/32 config=null
Mar 06, 2014 8:36:17 PM org.apache.catalina.startup.Catalina start
INFO: Server startup in 10800 ms
Hi Samar,
Take a look at this KB also the resolution. Please take a backup from your database before you procees with the resolutions.
Saleh
Those errors are often thrown if you've installed a newer Tomcat over an old one, instead of installing it "clean".
Did you start with a completely empty installation directory for the new system?
Thanks Saleh!! yes, it was the issue with collation_name =
'utf8_bin
I already fixed it though. Thanks again for your help
Hi Samar,
Glad to hear that. You are most welcome
Saleh
Yes, i already verified the permission for the directory. I also cleared the pugin cash but still getting the following error;
2014-03-10 10:19:51,743 INFO [Thread-48] [atlassian.plugin.manager.DefaultPluginManager] shutdown Shutting down the plugin system
2014-03-10 10:19:51,805 INFO [Thread-48] [com.atlassian.confluence.lifecycle] destroy Shutting down long running task service
2014-03-10 10:19:54,222 INFO [Thread-48] [com.atlassian.confluence.lifecycle] contextDestroyed Stopping Confluence
2014-03-10 10:28:47,085 INFO [main] [com.atlassian.confluence.lifecycle] contextInitialized Starting Confluence 5.4.3 [build 4732 based on commit hash f543bd9a3bbc12daed85f6f5e5cba84282599932]
2014-03-10 10:28:50,225 INFO [main] [springframework.web.context.ContextLoader] initWebApplicationContext Root WebApplicationContext: initialization started
2014-03-10 10:28:54,087 INFO [main] [com.atlassian.confluence.lifecycle] <init> Loading EhCache cache manager
2014-03-10 10:29:10,291 WARN [main] [org.springframework.beans.TypeConverterDelegate] findDefaultEditor PropertyEditor [com.sun.beans.editors.EnumEditor] found through deprecated global PropertyEditorManager
2014-03-10 10:29:21,206 INFO [main] [springframework.web.context.ContextLoader] initWebApplicationContext Root WebApplicationContext: initialization completed in 30980 ms
2014-03-10 10:29:21,711 ERROR [main] [atlassian.confluence.setup.BootstrapApplicationStartupListener] checkConfigurationOnStartup Detected tables with non-default collation. See https://confluence.atlassian.
2014-03-10 10:29:21,949 WARN [main] [atlassian.confluence.plugin.PluginFrameworkContextListener] contextInitialized Not starting full plugin system due to upgrade or licensing errors
2014-03-10 10:29:23,675 INFO [main] [com.atlassian.confluence.lifecycle] init Confluence is ready to serve
Hi Samar,
Don't worry we are here to help.
Check the permission of the directory and grant writable permission to your directory. I would also recommend you to clear the plugin cash.
Saleh
Can someone plz help me out? I am now getting the following error now. I am fighting with this issue all day
2014-03-07 18:39:13,577 INFO [Thread-43] [atlassian.plugin.manager.DefaultPluginManager] shutdown Shutting down the plugin system
2014-03-07 18:39:13,619 INFO [Thread-43] [com.atlassian.confluence.lifecycle] destroy Shutting down long running task service
2014-03-07 18:39:15,496 INFO [Thread-43] [com.atlassian.confluence.lifecycle] contextDestroyed Stopping Confluence
2014-03-07 18:39:21,440 INFO [main] [com.atlassian.confluence.lifecycle] contextInitialized Starting Confluence 5.4.3 [build 4732 based on commit hash f543bd9a3bbc12daed85f6f5e5cba84282599932]
2014-03-07 18:39:23,996 INFO [main] [springframework.web.context.ContextLoader] initWebApplicationContext Root WebApplicationContext: initialization started
2014-03-07 18:39:27,682 INFO [main] [com.atlassian.confluence.lifecycle] <init> Loading EhCache cache manager
2014-03-07 18:39:39,855 WARN [main] [org.springframework.beans.TypeConverterDelegate] findDefaultEditor PropertyEditor [com.sun.beans.editors.EnumEditor] found through deprecated global PropertyEditorManager
2014-03-07 18:39:48,213 INFO [main] [springframework.web.context.ContextLoader] initWebApplicationContext Root WebApplicationContext: initialization completed in 24217 ms
2014-03-07 18:39:48,603 ERROR [main] [atlassian.confluence.setup.BootstrapApplicationStartupListener] checkConfigurationOnStartup Detected tables with non-default collation. See https://confluence.atlassian.
2014-03-07 18:39:48,842 WARN [main] [atlassian.confluence.plugin.PluginFrameworkContextListener] contextInitialized Not starting full plugin system due to upgrade or licensing errors
2014-03-07 18:39:50,621 INFO [main] [com.atlassian.confluence.lifecycle] init Confluence is ready to serve
Thanks Saleh,
Please find below the atlassian confluence.log, I tried to attached it but its not working. So i paste it here. I also checked my database information and its pointing to right one.
Request Information
URL: http://*******/500page.jsp
Scheme: http
Server: ******
Port: 8089
URI: /confluence-test/500page.jsp
Context Path: /confluence-test
Servlet Path: /500page.jsp
Path Info: null
Query String: null
Attributes
javax.servlet.forward.request_uri: /confluence-test/
javax.servlet.forward.context_path: /confluence-test
javax.servlet.forward.servlet_path: /index.action
javax.servlet.forward.path_info: /500page.jsp
os_securityfilter_already_filtered: true
atlassian.core.seraph.original.url: /500page.jsp
javax.servlet.error.status_code: 500
javax.servlet.error.servlet_name: action
loginfilter.already.filtered: true
javax.servlet.error.message:
com.opensymphony.sitemesh.APPLIED_ONCE: true
com.atlassian.core.filters.HeaderSanitisingFilter_already_filtered: true
javax.servlet.error.exception: com.atlassian.util.concurrent.LazyReference$InitializationException: java.lang.NullPointerException
javax.servlet.error.request_uri: /confluence-test/
Parameters
caused by: com.atlassian.util.concurrent.LazyReference$InitializationException: java.lang.NullPointerException
at com.atlassian.util.concurrent.LazyReference.getInterruptibly(LazyReference.java:149)
caused by: java.lang.NullPointerException
at com.atlassian.spring.container.ContainerManager.getComponent(ContainerManager.java:33)
Hi Samar,
Catalina.log doesn't show reasons of problem. Please attach atlassian-confluence.log located on <confluence-home>\logs or look for error there.
I would also recommend you to check database information on <confluence-home>\confluence.cfg . Ensure that all your database elements are correctly informed.
Saleh
