Confluence label autocomplete does not work
Libor Šmíd February 18, 2020 edited
could someone help me with not working label autocomplete?
I found this article https://confluence.atlassian.com/confkb/confluence-label-autocomplete-does-not-work-in-a-certain-page-829068847.html, but it is not work for me - first query returns no result
confluence 6.15.2
Thank you in advance.
Libor
Edit: I found, that the issue is caused by Brikit Targeted Search for Confluence plugin. If I disable this plugin, autocomplete for labels work fine.
Any ideas why?
Thank you again
Libor Šmíd February 24, 2020
The problem is solved in the new Brikit Targeted Search for Confluence plugin version 2.0.1
