Confluence language problems
Andrey Zhupanenko May 13, 2014
Global Confluence language is set to English, but some labels are German.
Restriction popup as example http://screencast.com/t/tBjK0skj9
Fabio Racobaldo _Herzum_
Hello Andrey,
I found this open issue https://jira.atlassian.com/browse/CONF-23220#comment-350883
Probably, it is your browse language that cause this issue. Please, could you try the workaround proposed into the above issue?
Fabio
your link is not working
Hello Andrey,
please, could you check your default language? Each user can define its own language in its user preferences.
https://confluence.atlassian.com/display/DOC/Editing+User+Settings
Hope this helps,
Fabio
was "Auto" there and changed to "English". didn't helped.
tried to change to "French", bot English and German labels were changed to French
Register today
