Hi there,
I run the upgrade from 7.13.4 to 7.18.1 on Node 1 and the software started on this Node with no issues - after copying the file to node 2 using this command
rsync -av user@IP:/opt/atlassian/confluence /opt/atlassian/
the files are copied but are still cannot start the service in the Node 2
and I am getting errors and I think becuase in Node 2 the java OpenJDK version is 1.8.0
and in Node 1 ( where the service is running ) the java OpenJDK version is 11.0.
So if this is the problem How I can upgrade the JAVA Open JDK in Node 2?
22-Jun-2022 09:46:38.671 SEVERE [main] org.apache.catalina.startup.Catalina.start The required Server component failed to start so Tomcat is unable to start.
org.apache.catalina.LifecycleException: A child container failed during start
at org.apache.catalina.core.ContainerBase.startInternal(ContainerBase.java:938)
at org.apache.catalina.core.StandardEngine.startInternal(StandardEngine.java:263)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:183)
at org.apache.catalina.core.StandardService.startInternal(StandardService.java:432)
at org.apache.catalina.core.StandardServer.startInternal(StandardServer.java:927)
at org.apache.catalina.startup.Catalina.start(Catalina.java:772)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.base/java.lang.reflect.Method.invoke(Unknown Source)
at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:345)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:476)
Caused by: java.util.concurrent.ExecutionException: org.apache.catalina.LifecycleException: A child container failed during start
at java.base/java.util.concurrent.FutureTask.report(Unknown Source)
at java.base/java.util.concurrent.FutureTask.get(Unknown Source)
at org.apache.catalina.core.ContainerBase.startInternal(ContainerBase.java:926)
... 13 more
Caused by: org.apache.catalina.LifecycleException: A child container failed during start
at org.apache.catalina.core.StandardHost.startInternal(StandardHost.java:835)
at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1396)
at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1386)
at java.base/java.util.concurrent.FutureTask.run(Unknown Source)
at org.apache.tomcat.util.threads.InlineExecutorService.execute(InlineExecutorService.java:75)
at java.base/java.util.concurrent.AbstractExecutorService.submit(Unknown Source)
at org.apache.catalina.core.ContainerBase.startInternal(ContainerBase.java:919)
... 13 more
Caused by: org.apache.tomcat.util.MultiThrowable: 2 wrapped Throwables: [org.apache.catalina.LifecycleException: Failed to start component [StandardEngine[Standalone].StandardHost[localhost].StandardContext[]]][org.apache.catalina.LifecycleException: Failed to start component [StandardEngine[Standalone].StandardHost[localhost].StandardContext[/synchrony-proxy]]]
at org.apache.catalina.core.ContainerBase.startInternal(ContainerBase.java:930)
... 21 more
22-Jun-2022 09:46:38.671 INFO [main] org.apache.coyote.AbstractProtocol.pause Pausing ProtocolHandler ["http-nio-8090"]
22-Jun-2022 09:46:38.672 INFO [main] org.apache.catalina.core.StandardService.stopInternal Stopping service [Tomcat-Standalone]
22-Jun-2022 09:46:38.673 INFO [main] org.apache.coyote.AbstractProtocol.destroy Destroying ProtocolHandler ["http-nio-8090"]
22-Jun-2022 09:46:38.848 WARNING [main] org.apache.catalina.loader.WebappClassLoaderBase.clearReferencesJdbc The web application [ROOT] registered the JDBC driver [com.github.gquintana.metrics.sql.Driver] but failed to unregister it when the web application was stopped. To prevent a memory leak, the JDBC Driver has been forcibly unregistered.
22-Jun-2022 09:46:38.849 WARNING [main] org.apache.catalina.loader.WebappClassLoaderBase.clearReferencesJdbc The web application [ROOT] registered the JDBC driver [org.hsqldb.jdbc.JDBCDriver] but failed to unregister it when the web application was stopped. To prevent a memory leak, the JDBC Driver has been forcibly unregistered.
22-Jun-2022 09:46:38.849 WARNING [main] org.apache.catalina.loader.WebappClassLoaderBase.clearReferencesJdbc The web application [ROOT] registered the JDBC driver [com.mysql.cj.jdbc.Driver] but failed to unregister it when the web application was stopped. To prevent a memory leak, the JDBC Driver has been forcibly unregistered.
22-Jun-2022 09:46:38.849 WARNING [main] org.apache.catalina.loader.WebappClassLoaderBase.clearReferencesJdbc The web application [ROOT] registered the JDBC driver [com.microsoft.sqlserver.jdbc.SQLServerDriver] but failed to unregister it when the web application was stopped. To prevent a memory leak, the JDBC Driver has been forcibly unregistered.
22-Jun-2022 09:46:38.850 WARNING [main] org.apache.catalina.loader.WebappClassLoaderBase.clearReferencesJdbc The web application [ROOT] registered the JDBC driver [org.postgresql.Driver] but failed to unregister it when the web application was stopped. To prevent a memory leak, the JDBC Driver has been forcibly unregistered.
22-Jun-2022 09:46:38.850 WARNING [main] org.apache.catalina.loader.WebappClassLoaderBase.clearReferencesJdbc The web application [ROOT] registered the JDBC driver [org.h2.Driver] but failed to unregister it when the web application was stopped. To prevent a memory leak, the JDBC Driver has been forcibly unregistered.
22-Jun-2022 09:46:38.850 WARNING [main] org.apache.catalina.loader.WebappClassLoaderBase.clearReferencesJdbc The web application [ROOT] registered the JDBC driver [net.sourceforge.jtds.jdbc.Driver] but failed to unregister it when the web application was stopped. To prevent a memory leak, the JDBC Driver has been forcibly unregistered.
22-Jun-2022 09:46:38.851 WARNING [main] org.apache.catalina.loader.WebappClassLoaderBase.clearReferencesThreads The web application [ROOT] appears to have started a thread named [mysql-cj-abandoned-connection-cleanup] but has failed to stop it. This is very likely to create a memory leak. Stack trace of thread:
java.base@11.0.14.1/java.lang.Object.wait(Native Method)
java.base@11.0.14.1/java.lang.ref.ReferenceQueue.remove(Unknown Source)
com.mysql.cj.jdbc.AbandonedConnectionCleanupThread.run(AbandonedConnectionCleanupThread.java:91)
java.base@11.0.14.1/java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
java.base@11.0.14.1/java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
java.base@11.0.14.1/java.lang.Thread.run(Unknown Source)
