×Hi all,
I'd like to use the confluence search engine to search not only in Confluence but also in file directories on a specific server. I want the result to be the search in Confluence and in these directories. I want a global search. Is that possible ? And how ?
It seems the Confluence search engine would be limited to Confluence (that is not illogic!).
Is there a possibility to link Lucene to additional directories ? or the other way around to configure an external crawler in Confluence on Confluence data and files on separate directories ?
This is not possible with confluence standard functionality.
You probably have the server version. I would look in the apps to see if there was anything.
Hi Jean-Francois,
iFinder Confluence Search is the solution you are looking for. You can start directly with a trial.
You will find more information at our atlassian community article.
Please contact us at atlassian@intrafind.com if you need more information or if you like to get a demo first.
Best
Robby
Hi Jean-Francois,
regarding your search problem I would recommend you to have a look on our plugin - see here: https://marketplace.atlassian.com/apps/1222773/intergator-search-for-confluence?hosting=server&tab=overview .
On our website you'll also find further information --> https://www.intergator.de/en/solutions-and-showcases/use-cases-with-intergator/enterprise-search-atlassian-confluence/
If you have any questions, please feel free to contact me.
Anne
