Confluence problem with Collaborative Editing
Tomasz Bryla
I have a problem with configuring the proxy in Confluence. I configured by the article available in the knowledge base. However, when I try edit page with collaborative editing I get this error:
Something went wrong after loading the editor. Copy your unsaved changes and refresh the page to keep editing.
 Here my server.xml and proxy configuration. Can anyone tell my where is a problem?
server.xml
<Server port="8000" shutdown="SHUTDOWN" debug="0">
<Service name="Tomcat-Standalone">
<Connector port="8090" connectionTimeout="20000" redirectPort="8443"
maxThreads="48" minSpareThreads="10"
enableLookups="false" acceptCount="10" debug="0" URIEncoding="UTF-8"
protocol="org.apache.coyote.http11.Http11NioProtocol"
scheme="https" proxyName="confluence.mydomain.com" proxyPort="443"/>
<Engine name="Standalone" defaultHost="localhost" debug="0">
<Host name="localhost" debug="0" appBase="webapps" unpackWARs="true" autoDeploy="false" startStopThreads="4">
<Context path="" docBase="../confluence" debug="0" reloadable="false" useHttpOnly="true">
<!-- Logging configuration for Confluence is specified in confluence/WEB-INF/classes/log4j.properties -->
<Manager pathname=""/>
<Valve className="org.apache.catalina.valves.StuckThreadDetectionValve" threshold="60"/>
</Context>
<Context path="${confluence.context.path}/synchrony-proxy" docBase="../synchrony-proxy" debug="0"
</Context>
</Host>
</Engine>
</Service>
</Server>
And my proxy setup
server {
listen confluence.mydomain.com:80;
server_name confluence.mydomain.com;
## redirect http to https ##
rewrite ^ https://$server_name$request_uri? permanent;
listen 443 default ssl;
ssl_certificate /etc/nginx/ssl/2019.cert.pem;
ssl_certificate_key /etc/nginx/ssl/2019.cert.key;
if ($http_host != "confluence.mydomain.com") {
rewrite ^ confluence.mydomain.com$request_uri permanent;
index index.php index.html;
location / {
allow 10.0.0.0/8;
allow 172.16.0.0/12;
allow 192.168.0.0/16;
deny all;
proxy_set_header X-Forwarded-Host $host;
proxy_set_header X-Forwarded-Server $host;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_pass https://192.168.8.45:8090;
include /etc/nginx/proxy_params;
access_log /var/log/nginx/confluence.mydomain.com-access.log;
error_log /var/log/nginx/confluence.mydomain.com-error.log;
access_log syslog:server=192.168.8.21:12301 graylog2_format;
error_log syslog:server=192.168.8.21:12302;
location /synchrony {
proxy_pass http://192.168.8.45:8091/synchrony;
proxy_http_version 1.1;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection "Upgrade";
#location ~* \.(js|css|jpg|jpeg|gif|png|svg|ico|pdf|html|htm)$ {
Tomasz Bryla
Any ideas?
