Confluence redirects to HTTP when using HTTPS/nginx setup
pgoodyear
July 8, 2016
I've followed the guide at https://confluence.atlassian.com/doc/running-confluence-over-ssl-or-https-161203.html and its been working fine for some months now. We recently setup a new office and access to the Confluence server is only allowed on port 443/HTTPS.
When a user edits a page and saves it, the save back request goes to:
https://wiki.domain.com/pages/doeditpage.action?pageId=123456
This has a Status Code of 302 Found, and Response Header of
Location: http://wiki.domain.com/display/SPACENAME/pagetitle
So the user is redirected to HTTP which is blocked, they receive a time out and then change to HTTPS and all is fine.
The Server Base URL is set as HTTPS and everything else works, emails have the HTTPS links etc. Is this a bug, or is there an extra setting I can change somewhere in the configs to not redirect to HTTP.
Paul.
Olivier DUGAST
September 9, 2016
Hi
I have the same configuration and the same problem.
Do you have stilll your problem?
I've a 302 redirect with http:// protocole instead of https
Olivier
atlassian, atlassian community, job interviews, interview tips, career advice, interview preparation, job search, interview experiences, hiring process, atlassian careers, community discussion, interview best practices
Interview Tips & Pet Peeves ✍️
Join the discussion on interview best practices and common pitfalls. Share your experiences and learn from others in the Atlassian Community.
Share you experiences!
