Confluence (server) does not load remotely
Balaji November 8, 2017
Confluence server page (<IP>:8090) does not load if accessed remotely. On the same system where the server is installed, it loads fine. As such the link seems to be fine, since the Application link to Confluence inside a bitbucket server installation is fine.
Andrew Golokha
November 14, 2017
Hi Balaji,
Is it possible that a proxy or some other network device sits between the workstations and the server? Sometimes servers are set up on a backbone to "talk" to each other directly (so the application links would work) but workstations have to go through a firewall or proxy to reach the servers. For example, if the port 8090 is not accessible through the firewall it would cause you to be able to reach the other applications on other ports but not Confluence.
To gather more information, please try some network tests like trace route, ping and telnet. I can provide syntax if you let me know the operating system on the desktop computer.
Andrew
Lars Olav Velle
November 9, 2017
Let us know what you have tried so far? With this little information we can just guess and provide you with an endless number of things to check.
-Lars
Balaji November 14, 2017
Well I have installed bitbucket, jira and confluence servers. And connected one another in the application links. Except for Confluence, I am able to access the urls.
If I access Confluence locally (<server-ip>:8090) on the same server it works fine. Even created a trial "space" in Confluence.
New Confluence Admin Learning Path! 🤩
Confidently manage users, permissions, and content in Confluence. This self-paced learning path helps admins streamline collaboration, improve user experience, and apply the best practices to get the most out of Confluence in any cloud environment.
Start Learning Now
