Confluence showing JIRA isuues with descriptions
minghua March 29, 2018
The JIRA issues macro can do a list of issues by JQL search with custom fields. Is it possible to add also the description of each issues to the display? Ideally I'd like each issue is shown with a line of custom fields, followed by the description of the issue in multiple lines.
If the builtin macros cannot do it, any other plugins?
Anup
March 29, 2018
The JIRA issues macro has two main display options.
  1. Display as table
  2. Display as total issue count
If you choose to display as table, then the last configuration available under the Display Options configuration is Columns to Display. Here, you can select what all you'd like to show including the Description.
minghua March 30, 2018
Yes, this works for me. Except that it shows the descriptions in the same row. An ok solution. Thanks.
