Hello, I was trying to upgrade Confluence 5.6.3 to 6.15.3 Server running on Windows VM using latest installer.
However, I ran into problems. It appears that the SQL database structure changed.
Confluence cannot be started after upgrade.
Some examples of the log:
2019-04-23 21:00:00,450 ERROR [scheduler_Worker-1] [crowd.manager.application.ApplicationServiceGeneric] findUserByName com.atlassian.cache.CacheException: org.springframework.jdbc.UncategorizedSQLException: Hibernate operation: Could not execute query; uncategorized SQLException for SQL []; SQL state [S0002]; error code [208]; Invalid object name 'scheduler_clustered_jobs'.; nested exception is java.sql.SQLException: Invalid object name 'scheduler_clustered_jobs'.
com.atlassian.crowd.exception.DirectoryInstantiationException: com.atlassian.cache.CacheException: org.springframework.jdbc.UncategorizedSQLException: Hibernate operation: Could not execute query; uncategorized SQLException for SQL []; SQL state [S0002]; error code [208]; Invalid object name 'scheduler_clustered_jobs'.; nested exception is java.sql.SQLException: Invalid object name 'scheduler_clustered_jobs'.
The article https://confluence.atlassian.com/doc/upgrading-confluence-4578.html suggests there could be a direct upgrade.
Can somebody suggest a workaround?
Thank you.
did you check that your database server version is still supported?
Best
JP
Thank you for suggestion.
We run SQL Server 2014 SP2 in SQL Server 2012 compatibility mode.
According to https://confluence.atlassian.com/doc/supported-platforms-207488198.html, Confluence 6.15 supports SQL 2012
Microsoft SQL Server is not the preferred database for Confluence / Jira. Did you try an export backup of your Confluence site & reimport on a new Confluence installation?
Otherwise I would opt for opening a ticket with Atlassian.
Best
JP
