Hi All,
I use Confluence (6.2.3) in a new environment, and on it, all my SQL functions that return wiki or xhtml output (like displaying a button, or a Roadmap, or hyperlink) are not working correctly :
On HTML result, hyperlink are not working, and instead of that, I have "Unknown macro: {html}" display.
On XTML result, I have the code return by SQL function (i.e <ac:structure-macro...)
It seems only sql results are concerned, because if I insert a Roadmap chart or an HTML hyperlink on the page, it work correctly.
Of course, I haven't this problem on the old environment (but I have not the hand on old environment, so, I don't know what modify on config :( )
I check module, and All HTML / xhtml are enabled and working.
Any suggestions ?
thanks in advance
no idea ?
regards
