×Hi!
Is it possible to connect two spaces in Confluence with the same page tree and same information, then when I change something in one space, the same changes will be in the second space?
Thannks in advance,
Artem
not out of the box. We do something similar with the Comala Publishing Plugin .
With this plugin, you get a "draft" space (the one you are working in) and a public space. You keep both spaces in sync by publishing your changes from draft space to public space.
It works well, but is not for free.
