I have a jira service desk entities with knowlegde base connected.
I try to see an article from the portal of jsd but I have to click on the button to connect me to confluence. Is it a way to see directly the article ?
For informations, I use the OAuth (impersonation) for the application links.
Bonjour @valerian Baillet et bienvenue à la Communauté!
This looks like the users are defined in different directories. Please verify that Confluence is setup to manage users from the Jira directory: Connecting Confluence to Jira applications for User Management.
Merci!
I will try your solutions since I have the server ready to work
@valerian Baillet, if my answer addressed your problem, would you please 'Accept' it?
Which type of Application Link is connecting Jira to Confluence? Have found previously this works best with Oauth with impersonation...
Presuming this is server; this is best attempted on a staging environment rather than directly on production as this will mean users have to perform a one-time authentication after they login
See inside
