Connectivity Between two OnDemand Confluence servers
Cheryl Schmelzer
June 4, 2014
If we implement two different OnDemand instances, one for internal use and one for external use, is it possible for internal users to log into both instances with the same login?
Mallmann
June 4, 2014
Hi Cheryl,
I'm afraid it's not possible to have the same users/groups onto different OnDemand instances. It is possible to link the users with Google Apps, tough. However, you won't have the same groups configured in both instances.
Could you specify why you would need different instances to use with external and internal users? Configuring the right space/page and group permissions should do the trick to let external users share content with the internal ones.
Best regards,
Eduardo Mallmann
Atlassian Support
Cheryl Schmelzer
June 4, 2014
Thank you Eduardo. We are concerned about security and the ability to ensure that our "internal use only" documentation cannot be accessed by external users.
