Is there a way that I can copy a macro into a clipboard manager to use later?
Specifically, I want to be able to paste the Page Properties macro. I am able to copy and paste it but after copying it into a clipboard manager, It gets pasted back as just text.
---- Edit ----
As others have said, Confluence Source Editor would work for my purposes. In my case all I needed was a better clipboard manager! Thanks!
---- /Edit ----
Aaron
Hey,
I guess you would need a clipboard manager that support Unicode, HTML and richer formats and not just plain text.
There are quite a few available for different OS, for example, ArsClip for Windows.
If you are on Confluence server you can use an Atlassian app called "Confluence Source Editor".
You can copy the macro's storage format version and paste it in again when you need it. There is a small learning curve, but nothing serious.
