Create Block Diagram with Clickable Blocks
Oliver Chamberlin
Right now I know how to insert a diagram in Confluence and connect it to a hyperlink.
How do I create a block diagram with multiple clickable blocks that will link to other documents?
JP _AC Bielefeld Leader_
March 27, 2019
you can use any app from the Atlassian Marketplace. Depending on your Confluence version (Cloud or Server) there are different apps available:
Cloud:
https://marketplace.atlassian.com/search?category=Charts%20%26%20diagramming&hosting=cloud&product=confluence
Server:
https://marketplace.atlassian.com/search?category=Charts%20%26%20diagramming&hosting=server&product=confluence
The most relevant ones for your tasks are:
  • Draw.IO
  • Gliffy
  • Lucidchart
All three can accomplish the task of drawing block diagrams & link them somewhere.
We use Draw.IO & are quite happy.
Best,
JP
Oliver Chamberlin
JP,
I appreciate the answer. I just created my block diagram in draw.io. How do I publish it in Confluence with links?
OC
March 28, 2019
Right click on the object & select "Edit Link", enter the URL. When you save the drawing, the object will be linked to the URL
Like Jaroslav Pavlicek likes this
Oliver Chamberlin
I appreciate the fast response. Thank you for the information. I was not clear in my previous question. I already know how to edit a link to an object in my block diagram. I have links connected to objects in my block diagram. How do I publish this file in Confluence so that other users can open this block diagram and click on each object and link to documents that provide more information concerning that object?
Like 4 people like this
Andrew Rose February 14, 2022
Has there been any update to Confluence functionality which may help to insert multiple links onto an image?
For example onto a Process Flow diagram.
If not, I am thinking of creating multiple images, then inserting those into the cells of a table, and then hyperlinking from there to the related info.
Samie Delebo - Your Gal at Gliffy
Hi Andrew! I don't believe there's been an update like this. Like the solution above, you would probably need to use an additional diagramming app like Gliffy.
Like Ruud Dekker likes this
Ruud Dekker
November 10, 2022
Hi Andrew, I was looking for the same thing as you and came across the following : Scroll ImageMap for Confluence | Atlassian Marketplace.
I haven't tried it yet, but hopes it will do the trick for you!
Kind regards.
Bastian -drawio Diagrams-
Hey Oliver, Bastian from draw.io here. Linking to content is something that is requested frequently from our users. You have quite few options to achieve that with draw.io, please have a look at the following three blog posts:
Best wishes
Register now
