Create from template - Storage location selectable?
Luecke September 27, 2021
hi,
I have a "Create from template" button, but I want to choose also the storage location. Currently it only puts it in the respective space, but I would like to put these created pages on a child page below.
I have the possibility to work with a space key? does anyone know how this works or is there another solution?
many thanks!
2 accepted
Anshuman Dash _K15t_
October 20, 2021 edited
Hey Luecke,
We have recently built an app for Codegeist 2021 called Create From Template Pro.
The app is available for free on the Atlassian Marketplace and enables you to select a target location among other features :)
I hope that helps.
Cheers!
Dash
Luecke October 20, 2021
Hey Dash,
Thank you - unfortunately we do not have the cloud solution - too bad!
Cheers!
FREE
