I'm using the Create From Template button macro 4 times on the space homepage. Two of the buttons are supposed to create templates that are User Created Templates, and the other two are templates under Blueprint Templates (when looking at the Content Tools > Templates page)
The two that are under Blueprint open the create dialog and use the correct template, but they take you out of the space and off the page where the button was and to your personal dashboard.
The two User Created template buttons take you off the page, out of the space, and to your personal dashboard, AND they don't even open up the create dialog. So you're just outside of the space now, and not creating anything.
Also, the Create From Template macro buttons are all inside an Alert macro, if that matters.
Anyone know what's going on?
