Can anyone help with this issue please?
I have created a space and added four associated pages to the space.
I have added blog posts to the four associated pages with the intention they work independently to each other. However, they are not working as anticipated.
I.e. Creating a blog post on page 1 will also create the same blog on pages 2 - 4. The same applies for all pages. I.e. creating a blog post in 2 will also prompt the same blog post to display in pages 1, 3 & 4 & so on.
This is the code I am using:
{blog-posts:content=labels+page1|max=5|space=bio}
{blog-posts:content=labels+page2|max=5|space=bio}
{blog-posts:content=labels+page3|max=5|space=bio}
{blog-posts:content=labels+page4|max=5|space=bio}
Each page is titled page 1, 2, 3 and 4.
What do I need to add/remove to the above code to ensure each blog is independent of the other 3?
Many thanks in advance.
David
A Confluence blog is linked to the entire space rather than individual pages within the space. I do not think it is possible to create more than one blog in a space.
If you want to show certain blog-posts on different pages you should do the following:
This will show only the posts meant for each page in each page!
Rgrds,
// Svante
Glad to help :-)
