×Hi,
I've setup Crowd integration and also enabled SSO for the following applications:
jira
bitbucket
bamboo
confluence
following this documentation:
https://confluence.atlassian.com/crowd/adding-an-application-18579591.html
They are all on the same domain.
All work as intended except for confluence. The authentication part of it works, but the SSO does not work. I'm not able to find any errors that may help me troubleshoot this, and was hoping the community can help lead me in the right direction.
I've updated the seraph-config.xml and the crowd.properties file.
Please let me know if there is a particular log file I should look into, or if there is anything else you can think of.
Another thing I'm noticing that may be a clue is that, if I'm logged in to confluence and all the other apps.. and logout of confluence it logs me out of the other apps. Then when I log in to jira i can connect to bamboo and bitbucket, but confluence it still asks for my credentials.
