Custom Confluence Macro: Adding additional parameter is not getting reflected
Yagnesh Bhat
August 26, 2021 edited
I have a custom confluence macro developed as a part of the plugin. So far, we've had that macro accept one parameter. Now we added a second parameter from the atlassian-plugin.xml like so:
<parameter name="newParam" required="true">
<option key="showNameInPlaceholder" value="false"/>
<option key="showValueInPlaceholder" value="false"/>
</parameter>
The problem is inspite of adding this in the atlassian-plugin.xml and after refreshing my local dev environment, the storage format doesnt seem to get updated in either edit mode or view mode of the macro inspite of adding something as direct as
params.put("newParam", 12345);
as a first line in the body of the below execute methods in the macro code
public String execute(Map<String, String> parameters, String body, ConversionContext conversionContext) throws MacroExecutionException
public String execute(final Map params, final String body, final RenderContext renderContext) throws MacroException
 Please advise if there is anything I am missing or if there is anything I can troubleshoot. At the end we just want to make sure that this macro is able to accept his new parameter for all the older usages as well as any new usages.
