×I've downloaded and installed the test version of Confluence. In the site admin, the Default theme is selected. When I edit the Layouts (i.e. create custom layouts), they have no effect no matter what I do. What am I missing?
If you are using the Demonstration space that ships with Confluence, then it is not using the site-wide default theme, instead it has a space-level theme applied. This will be overriding the custom layouts.
To work around this, you can either:
Hope that helps,
Mark
